Daily form
Bacilioc
Daily form
Post by Bacilioc »
Normal
0
false
false
false
EL
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Êáíïíéêüò ðßíáêáò";
mso-tstyle-rowband-size:0;
mso-tstyle-colband- size:0;
mso-style-noshow:yes;
mso-style-priority:99;
m so-style-qformat:yes;
mso-style-parent:"";
mso-padding-a lt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin-top:0cm;
mso-para-margin-right:0c m;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0 cm;
line-height:115%;
mso-pagination:widow-orphan;
fon t-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-a scii-font-family:Calibri;
mso-ascii-theme-font:minor-latin ;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi- font-family:Calibri;
mso-hansi-theme-font:minor-latin;}
Normal
0
false
false
false
EL
X-NONE
X-NONE
line-height:115%;
fon t-size:11.0pt;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:mi nor-latin;
mso-fareast-language:EN-US;}
First
I need to print the document in .docx format. This way,  the only thing that changes is the date.
I want to make a task
which the following will be determining:
1. The
date of start
2.
2. The entire
amount of dates
3.       3. Print the related documents
The
date's
format follows as: (dddd, dd mmmm yyyy) (Tuesday, January 31, 2012) and in
Greek.
Example: From 01/02/2012 to
26/02/2012 (25 days) to 25 printed
documents with the corresponding date.
Normal
0
false
false
false
EL
X-NONE
X-NONE
line-height:115%;
fon t-size:11.0pt;
table.MsoTableGrid
{mso-style-name:"ÐëÝãìá ðßíáêá";
mso-tstyle-colband-s ize:0;
mso-style-priority:59;
mso-style-unhide:no;
bor der:solid windowtext 1.0pt;
mso-border-alt:solid windowtext .5pt;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-border-insideh:.5pt solid windowtext;
mso-border-insidev:.5pt solid windowtext;
mso-para-margin:0cm;
mso-para-margin-bottom: .0001pt;
font-size:11.0pt;
mso-ascii-font-famil y:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-f ont-family:Calibri;
ms o-fareast-language:EN-US;}
Tuesday, 31 January 2012
Location
Employ:
Product 1
Product 2
Product 3
Product 4
Product 5
Product 6
Daily form
Do you want to select files by their date?
I think that this is possible.
Bacilioc
Daily form
Post by Bacilioc »
Thanks for the reply.What I want is to print several papers from a file (dailyreport.docx). Just every time to want print a paper to change the date.This document is a table as shown above. The only thing that changes each time to print is the date (red)
