Creating a file list, excluding folders
stevefromdodge
Post by stevefromdodge »
I'm trying to create a file listing in a large directory, excluding a list of subfolders.I've got it working using nested loops to compare every file to every excluded folder, but it's incredibly inefficient and is taking an hour to run.Does anyone have any better ideas?
Give me example of necessary folder and list of excluding subfolders, please.
It seems there is simple solution if excluded subfolders are in 1-st level of initial folder.
Bacilioc
Post by Bacilioc »
What is the simple solution to excluded subfolders are in 1-st level of initial folder?In my example I have a folder with the following structure: W: \ Customer1 \ Files \ Music W: \ Customer1 \ Files \ Documents W: \ Customer1 \ Files \ Downloads W: \ Customer1 \ Files \ CustomFolder W: \ Customer2 \ Files \ Music W: \ Customer2 \ Files \ Documents W: \ Customer2 \ Files \ Downloads W: \ Customer2 \ Files \ CustomFolderetc.... I want to creat list of all files except the files from the folder "Music" and "Documents". In fact there are over 500 Customers and each folder "Files" contains 50 subfolders from which I exclude the 30!! Have you any idea?
Algorithm is a bit complicated, but this can be solved
See this example, please
this task works with structure:
C:\ incoming\customers\ customer1\files\ CustomFolder
C:\ incoming\customers\ customer1\files\ Documents
C:\ incoming\customers\ customer1\files\ Downloads
C:\ incoming\customers\ customer1\files\ Music
C:\ incoming\customers\ customer2\files\ CustomFolder
C:\ incoming\customers\ customer2\files\ Documents
C:\ incoming\customers\ customer2\files\ Downloads
C:\ incoming\customers\ customer2\files\ Music
etc...
You can specify your own start folder
The task selects all files from folder
customerN\files
without subfolders Music and Documents
You can specify your own list of folders too.
Bacilioc
Post by Bacilioc »
Normal
0
false
false
false
EL
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Êáíïíéêüò ðßíáêáò";
mso-tstyle-rowband-size:0;
mso-tstyle-colband- size:0;
mso-style-noshow:yes;
mso-style-priority:99;
m so-style-qformat:yes;
mso-style-parent:"";
mso-padding-a lt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin-top:0cm;
mso-para-margin-right:0c m;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0 cm;
line-height:115%;
mso-pagination:widow-orphan;
fon t-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-a scii-font-family:Calibri;
mso-ascii-theme-font:minor-latin ;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi- font-family:Calibri;
mso-hansi-theme-font:minor-latin;}
Thanks
for the
help.
With the above task (making some changes) was able to delete 85.000
files, about 142GB!
