Deleting a line from a text file
stevefromdodge
Post by stevefromdodge »
I have a script that's using "Search for files" to create a file listing called FileList.txt.I would like to scan FileList.txt and delete all of the lines that start with a certain string.Ideas?
You should rewrite all text in the loop and miss certain lines
See this example, please
Re: Deleting a line from a text file
Previous link was dead, Correct link
Corrected, thank you.
When we transferred information from old forum engine some information may be lost
You can find all published examples here: http://robotask.com/samples/
