Create file list- include file date?
minor
Post by minor »
I'm wondering if it's possible to add a line to create
file list that includes the date the file was created or
modified.
For example, current output is
1.txt
2.txt
3.txt
And the ideal output would be
1.txt 12/26/2011
2.txt 12/25/2011
3.txt 12/20/2011
Thanks,
Leslie
See the example below. This task makes the list of TXT files from c:\incoming folder with date in your current format
CatID=INTEGER|1380072790
ExternalName=STRING|"Task1134"
ID=INTEGER|1867208249
LocalVariables=STRING|"cfile,newtext,filetime"
Name=STRING|"List of files with file date"
Name=STRING|"//with date in your format"
comment=STRING|"with date in your format"
Name=STRING|"File Loop"
date1=STRING|"20111227"
date2=STRING|"20111227"
destvar=STRING|"CFILE"
DuringMinutes=STRING|"1"
file0=STRING|"C:\incoming\*.txt"
filecount=STRING|"2"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"FILETIME"
WithoutPath=STRING|"1"
colon=STRING|"0"
comma=STRING|"0"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"1"
spaceasone=STRING|"0"
string=STRING|"{filetime}"
tab=STRING|"0"
variable=STRING|"filetime"
Name=STRING|"Set variable ""NEWTEXT"" with value ""{newtext}{cfile} {filetime(0)}{EOL}"""
varname=STRING|"NEWTEXT"
varvalue=STRING|"{newtext}{cfile} {filetime(0)}{EOL}"
Name=STRING|"Create Folder (c:\temp)"
newfolder=STRING|"c:\temp"
Name=STRING|"Create text file c:\temp\list.txt"
fileexists=STRING|"0"
filname=STRING|"c:\temp\list.txt"
line0=STRING|"{newtext}"
suppress=STRING|"1"
Name=STRING|"Run ""list.txt """
ifnonzero=STRING|"0"
program=STRING|"c:\temp\list.txt"
runas=STRING|"0"
wait=STRING|"0"
minor
Post by minor »
This is perfect, thank you!
minor
Post by minor »
Would it be possible to change the format of the date?
I've
looked at the filetime variable, and I don't see an
obvious
way to do it..
Ideally, I'd like the date format to be something like
YYMMDD, however I have no idea how to do this
edit:
Actually, I think I figured something out from looking at
samples. Downloaded the basic plug-in and put an extra
step in the task you posted above to evaluate & added an
extra local variable in
Name=STRING|"Evaluate"
expression=STRING|"format(#{filetime(0)}#, ""yymmdd"")"
variable=STRING|"FORMATTEDDATE"
{newtext}{formatteddate}{cfile}{EOL}"""
varvalue=STRING|"{newtext}{formatteddate}{cfile}{EOL}"
Please let me know if there is a better way to do this,
otherwise I will stick with this solution
You have forestalled me .
I want to say that you can do complex string transformation with actions of Basic plugin (Evaluate or Basic Script)
