How to determine the length of a filename
thegmanagain
Post by thegmanagain »
How do I determine the length of a filename and act on it accordingly.
Thanks,
Gavan
There is {StrLength()} system variable
you can use it such:
{StrLength(Some string)}
{StrLength({filename})}
also see small example below:
CatID=INTEGER|827538953
ExternalName=STRING|"Task1118"
ID=INTEGER|2146977976
LocalVariables=STRING|"filename"
Name=STRING|"length of filename"
Name=STRING|"File Loop"
date1=STRING|"20111208"
date2=STRING|"20111208"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"C:\incoming\*.txt"
searchkind=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
WithoutPath=STRING|"1"
Name=STRING|"Show ""{filename}"""
msg0=STRING|"{filename}"
msg1=STRING|"length of name {StrLength({filename})}"
msgcount=STRING|"2"
thegmanagain
Thanks Oleg
