Triggering Events - check windows existl
Boris
Post by Boris »
Tell, how it is possible to make in Triggering Events start if there is window exist (or not) or not no such started process (with a full patch to exe file)?
You can do such functionality. Create the task with Cyclic trigger.
Suppose it fired every 2 seconds.
Algorithm of the task is simple:
Check existence of window //Check for window action
If true
   do something
else
   do something else
endif
Also see the example below.
You can use similar algorithm for checking of some process existence. See {IsProcessExists()} variable.
CatID=INTEGER|444444824
ExternalName=STRING|"Task1089"
ID=INTEGER|742207139
LocalVariables=STRING|"w_exists"
Name=STRING|"Check existence of the window"
ToLog=INTEGER|2
ActionID=STRING|"A_WINDOW_CHECK"
Name=STRING|"Check for Window"
abortif=STRING|"0"
action=STRING|"1"
checkfor=STRING|"0"
exact=STRING|"0"
variable=STRING|"w_exists"
wincaption=STRING|"notepad"
value1=STRING|"{w_exists}"
msg1=STRING|"Notepad is working!"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"Notepad is not exists"
UnigueID=INTEGER|699214014
id=STRING|"KJVEQR74"
interval=STRING|"2"
Boris
Post by Boris »
This method works, but unfortunately, I can't add simultaneously in a condition of operation of the task any additional condition (for example, at file creation that too this condition worked).in rus: Ìåòîä ðàáîòàåò, íî íåëüçÿ äîáàâèòü äîïîëíèòåëüíîå óñëîâèå ñðàáàòûâàíèÿ, íàïðèìåð, ïî ïîÿâëåíèþ íîâîãî ôàéëà (óñëîâèå íå èìååò ñìûñëà, ò.ê â ñàìîé çàäà÷å òîæå ñîäåðæèòñÿ óñëîâèå).
Why not?
see such algorithm:
Task1 (with cyclic event):
If true
   start task2
end if
Task2 (with file monitor trigger and other events):
do something
Also, pay attention, that you can start another task with parameters.
