Which Event triggered @ Multi-events Task
Hi Oleg .  As we talk over here "Which Event was trigger ?" I still think, It will be very handy, If we have an action to determine which event is triggered at a multi-events Task! . As you mention over there, We can use separate tasks with one trigger inside each of them and then using a vriable inside each task to set the trigger name and call main task! But! it is not good idea for some tasks with same purpose! . For instance, I had to create 6 seperate task and each one with one trigger to monitoring different dial-up connections for connecting/disconnecting purpose!!! but with an action to determine which event is triggered, I can combine those 6 tasks in one task!!Good Luck IgImAx
