If Then / FileExists / List File
lordgrinz
Post by lordgrinz »
I am trying to use the following statement utilizing a filelist, it only works if there is only one file listed in the filelist. This is a check before I send an email containing attachments from this filelist. Is there a way to make this check work on all files in the list?{FileExists({TextFile({cFileList})})}
lordgrinz
Post by lordgrinz »
I should have mentioned I am using an "If Then" statement and a Boolean for a an if value is "True".
You can create the list of existing files by "Search for Files" action.
Next you can specify as attachment the following expression:
{TextFile(file_name)}
where file_name is the full name of created text file.
lordgrinz
Post by lordgrinz »
Oleg wrote:You can create the list of existing files by "Search for Files" action.
I've done that, but I am trying to do an IF THEN boolean check against the filelist, before sending the email. Like the following IF {FileExists({TextFile({cFileList})})} = True THEN ....run actionsProblem is that the FileExists function won't run against a filelist
Regarding to {FileExists()} variable
You should use only file name as parameter, like this:
{FileExists(C:\temp\file.tmp)}
or variable which contains single file name
{FileExists({MyFile})}
you can't use the list of filenames. If you have the list you should process it in the text loop
Regarding to your task:
I think that you don't need to uese {FileExists()} variable. See the example below:
CatID=INTEGER|1005538731
ExternalName=STRING|"Task1081"
ID=INTEGER|1670688694
LocalVariables=STRING|"filelist"
Name=STRING|"Send files in folder"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"c:\temp\list.txt"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Name=STRING|"Create File List (c:\temp\list.txt)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20110725"
date2=STRING|"20110725"
destfile=STRING|"c:\temp\list.txt"
DuringMinutes=STRING|"1"
file0=STRING|"c:\incoming\*.abc"
searchkind=STRING|"0"
subdirs=STRING|"1"
operator=STRING|"7"
value1=STRING|"{TextFile(c:\temp\list.txt)}"
Name=STRING|"Show ""File list is empty!!!!"""
msg0=STRING|"File list is empty!!!!"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Send Email"
attach0=STRING|"{TextFile(c:\temp\list.txt)}"
attachcount=STRING|"1"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"user@domain.com"
host=STRING|"localhost"
html=STRING|"0"
msg0=STRING|"See files in attachment"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"Files"
to=STRING|"user1@domain.com"
