Reg Expression - Find/Replace Inside File
MCHAL
Post by MCHAL »
Hi,Could you anyone of you guys tell me how a Reg Expression should read for replacing a string such as  "English" with "Portuguese" inside an .xml file?Thanks in advance.Kind regards.
See the example below
XML is a text file, because this example should help you.
CatID=INTEGER|1597096124
ExternalName=STRING|"Task1079"
ID=INTEGER|462569279
LocalVariables=STRING|"newtext"
Name=STRING|"Regexp demo - Replace English to Portuguese"
Name=STRING|"RegExp Replace"
anchored=STRING|"0"
extended=STRING|"0"
file=STRING|"C:\incoming\sample.txt"
linecount=STRING|"0"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)(english)"
replacementcount=STRING|"0"
repline00000000=STRING|"Portuguese"
replinecount=STRING|"1"
singleline=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"1"
variable=STRING|"newtext"
Name=STRING|"Create text file C:\incoming\sample1.txt"
fileexists=STRING|"0"
filname=STRING|"C:\incoming\sample1.txt"
line0=STRING|"{newtext}"
suppress=STRING|"0"
Also I put this task into our repository
MCHAL
Post by MCHAL »
Oleg wrote: Also I put this task into our repository
Hi, Oleg.
Thanks so much! It works great!
All the best!
