special characters
Giftpilz
special characters
Post by Giftpilz »
Hi Folks
I have a problem with robotask
During "Synchronizing" file folders it is not recognizing "special Characters"
Like German: "Ä" Ü" or
Turkish, Polish, Chinese ...
Any Idea for a work around?!?!?!
Because in principle Robotask" is brilliant -I Love It
but I have a lot of international contacts and receive files with "special Characters"
special characters
Unfortunately, RoboTask is nonunicode program as yet.
Therefore it may have problems with national symbols.
Check international (regional) settings in your Control Panel. If you setup the correct default language for non-unicode programs, RoboTask should work correctly.
In your case you should set German language.
