How to close popped-up window?
awesome7749
Post by awesome7749 »
Hi guys, I wonder if you  could help me how to figure out this.I use robotask to run some program named AndorSolis. Each time, I will send a keystroke "ctrl + S" to save the image I just captured. However, the saved image will pop up inside the AndorSolis window. Since I will have to take 200 images, I need to close this window. My first approach is to just move mouse to the object, and click. This works, but sometimes fails just because the window positions are different, or the window is blocked by some other programs. I wonder if there's an more elegant way of  closing this pop-up window. Thanks a lot!
You can send "Esc" or "Enter" key to popup dialog.
See "Send Keystroke" action
