Open an Browser Windows
logisch
Post by logisch »
Hi, how can I open an Windows in the browser e.g. MS Internet Explorer, to open a site to start a .php-File, e.g. www.xyz.com/start.php. I can do it manuallay, but I will do this with the RoboTask, which should open these windows every day one time. Thanks for your hints. Stefan
You should use "Run Application/Open Document" action, but in "Program or Document filename" parameter type this line:
http://www.xyz.com/start.php
logisch
Post by logisch »
Thanks to Oleg - It works - great!  The window is opening. I have four windows to open. One of these windows has checkboxes, which I have to click on - Is this also possible to do it with RoboTask? Thank You!
