Java App not accepting input keys/mouse
markus1
Post by markus1 »
I am having problems getting a standalone java-based application to accept keyboard input from Robotask.  My script is simple with only two tasks:  launch the app (this works fine) and send keys.  I have tried variations for SendKeys task including "Emulate KeyPress" and "Send as Simple Text" with no behavior difference.The window is detected because it rises to the top window when I manually run the Send task.  The text field is active and the text cursor is blinking in the login text field area.I tested and I have no problems getting input to work on Notepad or other similar utilities, so I know it is not a case of operator error.Robotask system log says: I: 6/4/2011 9:57:21 AM: Starting Task [Run "thinkTDA.exe "...] Cause: Manual runI: 6/4/2011 9:57:29 AM: Starting Task [Send keys to "Logon"] Cause: Manual runIf you want to try to duplicate this issue, the java application is available for free download at https://www.thinkorswim.com/tos/suiteFr ... g-s.tos.My configuration:Win7 SP1 64bitRobotask 4.4 patch #3I looked on this forum for any issues related to standalone Java apps but found next to nothing.Let me know if I can provide other information related to my problem in order to get this resolved.  Thanks for your kind assistance!
Check the following:
You need to do some timeout (a few seconds) in order to give some time to launched application.
Insert the "pause" action after the launching of your application.
