Find errors in logs
JMBPHP
Find errors in logs
Post by JMBPHP »
Have a task scheduled to run a .vbs to check the logs for the word ERROR and generate a MSGBOX with the log name.   Since the log name are RTcreated it can be cumbersome to review the log and quickly determine which task had a error since the logs do not contain the "given" task name.
Is there a table or other option that would give the name of the task?
Find errors in logs
See system variables in "Task Information" group:
{TaskCategoryID}
{TaskExtName}
{TaskID}
{TaskName}
You can pass this information to your VBS script.
But pay attention: these variables can work only in the task context.
See the example below:
CatID=INTEGER|1663346572
ExternalName=STRING|"Task206"
ID=INTEGER|1728171285
Name=STRING|"Test Task Infomation"
Name=STRING|"Show ""Category: {TaskCategoryID}"""
msg0=STRING|"Category: {TaskCategoryID}"
msg1=STRING|"External name: {TaskExtName}"
msg2=STRING|"Task ID: {TaskID}"
msg3=STRING|"Task Name: {TaskName}"
msgcount=STRING|"4"
