FTP Download
AndrewTraub
FTP Download
Post by AndrewTraub »
I've created a simple ftp task that consists of:1.  FTP Log On - works2.  FTP Change Folder - disabled currently3.  FTP File Loop : By files, remote folder = logs/*.gz, assign file name to {LOGFILE}, without full path checked  4.  FTP download : Remote File: {LOGFILE}5.  End Loop6.  FTP Log OffThe problem is that on step 3, I get this error:W: 5/17/2011 2:03:55 PM: FtpFindFirstFile fails with message: (12002) The operation timed out<CR><LF>I can verify that a file exists in the logs folder with the .gz suffix.  What am I missing?Thanks,
FTP Download
We'll try to investigate the problem.
Unfortunately I can't say anything right now
AndrewTraub
FTP Download
Thanks - would appreciate a solution.Andrew
jemesright
FTP Download
Post by jemesright »
Each ftp client has been specifically designed to suit various uploading tasks. If you are in doubt about which ftp client is most suitable we recommend you just download and try them. Fling FTP Software is a powerful ftp program that sets itself apart from other ftp clients by seamlessly integrating with your local Windows explorer.
luccysbgh
FTP Download
Post by luccysbgh »
got it.
