Repeating a task (macro)
yellow281
Post by yellow281 »
Hi all,
Thanks in advance for any advice. I have searched around
but cannot work out how to have a macro repeat. Basically
I have a spreadsheet of 3,000 lines of search terms of
which I want to perform a search on each one. It goes
like this;
1. Open spreadsheet
2. Copy cell
3. Enter search term in other app
4. Save results
5. Return to spreadsheet and delete original term
6. Repeat from Step 2
I have saved the above as a macro but I can't find where
to have steps 2-5 repeat.
Thanks!
Look at the "Loops and flows" group.
I think that Simple Loop is able to help you.
yellow281
Post by yellow281 »
What is the Loops and Flows group please?
Do you use RoboTask Lite?
RoboTask Lite doesn't contain "Loops & Flows" actions. Also many other actions are included in full version only. See comparison table.
