trigger every other week
racheney
Post by racheney »
Thank You oleg for your answer on "trigger 3rd tue of month".
Do you have an algorithm to perform a task every other week
reguardless of which day IE: week 1,3,5,7,9,etc. without checking the week# 52 times.
There is WeekOfTheYear system variable
You can calculate whether WeekOfTheYear is odd or even.
Use Evaluate action (in Basic group) for this purpose with the following expression
{WeekOfTheYear({Date})} mod 2
if expression is 0 then the week # is even, otherwise - odd.
algorithm will be such:
evalate {WeekOfTheYear({Date})} mod 2 // and save to Num variable
if {NUM}>0 then
   do something
end if
racheney
Post by racheney »
Thanks again Oleg,
I founf the evalate and the {WeekOfTheYear({Date})} but i could not find any wat to check for even/odd.
where can i get a list of modifiers like the "mod 2" used here?
You should install additional Basic plugin.
Download here.
You can find the full help of built-in Basic. Press F1 in action editor (for Evaluate and Basic Script actions)
See the example below:
CatID=INTEGER|1931015449
ExternalName=STRING|"Task1064"
ID=INTEGER|153548598
LocalVariables=STRING|"num"
Name=STRING|"Even or odd week"
Name=STRING|"Evaluate"
expression=STRING|"{WeekOfTheYear({Date})} mod 2"
variable=STRING|"NUM"
value1=STRING|"{num}"
value2=STRING|"0"
Name=STRING|"Show ""This is EVEN week"""
msg0=STRING|"This is EVEN week"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""This is ODD week"""
msg0=STRING|"This is ODD week"
