Simple Question for the Pro’s
advsign
Post by advsign »
I am trying to get it to do some what should be simple task. I have no programming experience do know what to do. Here is the task: 1. open a website link.2. keep it open for 60 seconds.3. close for 10 seconds.4. Repeat the steps.I need to do this for at least 8 hours per day.Can this be done with robotask?Thanks in Advance
see the example below.
It opens Google page for 60 sec from 8:00 to 16:00 every day.
Sate the task text into file and use menu Task|Import to import into RoboTask.
Automat=INTEGER|1
CatID=INTEGER|450925781
ExternalName=STRING|"Task1063"
ID=INTEGER|948766042
Name=STRING|"open site for 60 sec"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{Hours}"
value2=STRING|"8"
operator=STRING|"4"
type=STRING|"1"
value2=STRING|"16"
Name=STRING|"Run ""//www.google.com """
ifnonzero=STRING|"0"
program=STRING|"http://www.google.com"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Delay 60000 ms"
delay=STRING|"600"
Name=STRING|"Close window ""Google"""
action=STRING|"4"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"0"
wincaption=STRING|"Google"
id=STRING|"5WYSSBGF"
interval=STRING|"70"
