trigger 3rd tue of month
racheney
Post by racheney »
Is it possible to set a trigger for the 3rd tuesday of the month?
3rd tuesday of the month always has day number between 15 and 21.
You should do the following:
attach weekly scheduler to the task (each tuesday);
in the task use such algorithm:
if {day} >= 15 then
   if {day} <= 21 then
      do something
   end if
end if
Thus, your code will work only at 3-rd tuesday of the month.
Also see this topic with similar problem.
racheney
Post by racheney »
Thank you,
I didn't think adout putting it in the actions section,
just the trigger section.
