opening files in sequential order
cormorant_80
Post by cormorant_80 »
I have no experience with this type of program but have been assigned a task that will take a long time to complete manually and I'm hoping Robotask can help with.
There are about 1500 video files in a proprietary format, using the viewing program that reads the files and for each file I need click the menu item to open an archived file, select an archive file from the list, open it, click a button in the viewing program to generate a snapshot of the footage then click OK.
The task is fairly basic but I want to know if Robotask can do this so that each time the archived file has to be selected it opens the next one in sequence from the one that was opened immediately before.
Any tips much appreciated!
Try File Loop action.
You can specify mask of files and process these files sequentially.
