remove line breaks from variable
Brad
Post by Brad »
I am extracting info from an email and writing it to a text file.Sometimes the user writes information over 2 lines and I need to write it as a single line.For example:"Level 239 main street"Needs to be written as "level 2 39 main St"Ideally replace the new line with another character - perhaps a '-'.Can't be comma as the output is comma delimited.Any ideas?
Brad
Post by Brad »
should probably mention that "Level 239 main street"is held as a single variable, and this is the exception to the typical data I  am extracting.
See the example below. I made two replacements
symbol #13 (CR) to empty string
symbol #10 (LF) to "-" char.
Save the text of task to file and use menu Task | Import
CatID=INTEGER|839555382
ExternalName=STRING|"Task1014"
ID=INTEGER|2034820528
LocalVariables=STRING|"MyStr"
Name=STRING|"Remove EOL symbols"
Name=STRING|"Set variable ""MYSTR"" with value ""Level 2{EOL}39 main street"""
varname=STRING|"MYSTR"
varvalue=STRING|"Level 2{EOL}39 main street"
Name=STRING|"Show ""{Mystr}"""
msg0=STRING|"{Mystr}"
Name=STRING|"STR Replace"
mode=STRING|"0"
source=STRING|"{MyStr}"
substring=STRING|"{Chr(13)}"
variable=STRING|"MyStr"
mode=STRING|"0"
replacement=STRING|"-"
substring=STRING|"{Chr(10)}"
Brad
Post by Brad »
Perfect - thank you :)
