Too long text loop
steph@vds
Too long text loop
Post by steph@vds »
Is there a way to accelerate a text loop task ?
Thanks by advance.
Here is my task :
CatID=INTEGER|253659922
ExternalName=STRING|"Task9"
ID=INTEGER|1580846813
Name=STRING|"Family Movie : 042_Log Import"
Name=STRING|"Text Loop"
destvar=STRING|"LINELOGTOTAL"
file=STRING|"{DOSSIERLOG}\Log_Total.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos Nom Projet"
case=STRING|"1"
from=STRING|"1"
search=STRING|"{PROJET}"
source=STRING|"{LINELOGTOTAL}"
variable=STRING|"PROJETMATCH"
Name=STRING|"STR Pos Etat Import"
from=STRING|"1"
search=STRING|"IMPORTED_"
variable=STRING|"ETATIMPORT"
Name=STRING|"Si le projet matche"
value1=STRING|"{PROJETMATCH}"
Name=STRING|"Et si jamais importé"
operator=STRING|"1"
value1=STRING|"{ETATIMPORT}"
Name=STRING|"Create text file
{DOSSIERLOG}\Log_Import.txt"
fileexists=STRING|"1"
filname=STRING|"{DOSSIERLOG}\Log_Import.txt"
line0=STRING|"{LINELOGTOTAL}"
suppress=STRING|"0"
Too long text loop
How many lines in the text?
How much time it takes to process this file?
Try to insert into beginning of the task the action "Minimize RoboTask". The task will be executed faster, when main window is hidden.
steph@vds
Too long text loop
Post by steph@vds »
Hi Oleg,
I've made a test with a 3300 lines text file and it takes
about 1min40sec to complete. When I minimise Robotask, it
takes only about 30sec. It's great.
Is there another way to do such a loop ?
In other words, is there a way to help RT to do is his job
faster ?
Thanks for you help.
Steph@vds
Too long text loop
Also you can save some time if you write text file only ones at the end of the task.
You can form your text in memory in the loop and write it to file after the loop.
Algorithm is simple:
Set variable MyText with ""
Text Loop
   if then
      Set variable MyText with {MyText}{LINELOGTOTAL}{EOL}
      //with expanding of Variable value
   end if
end loop
Write Text File with {MyText}
