Edit a text file
Gekseppe
Edit a text file
Post by Gekseppe »
Hi;
I would need some help in writing a task with the following purpose:
1) monitor recursively a folder;
2) in case of new files, for each file, remove the following text from the header (the first 45 chars of the file):
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
3) save edited files in a new folder;
4) delete original files;
5) send new files by mail.
Any help will be really appreciated !
Edit a text file
Can you send me an example of such file (oleg (at) robotask.com)?
I think that this job can be solved by using BASIC script (removing of 45 chars from header).
In order to implement the rest steps look at the following actions:
File loop
Text loop
Delete file
Send email
and
File monitor triggering event
Gekseppe
Edit a text file
Post by Gekseppe »
You got it: thanks !
Edit a text file
My example of Basic script is below.
Sub Main
  Dim in_file As String
  Dim out_file As String
  Dim buf As Byte
  Dim i As Long
  in_file = RoboTaskApp.ExpandText("{in_file}")
  out_file = RoboTaskApp.ExpandText("{out_file}")
  'in_file = "C:\incoming\SALE-NO-NA100249-5958.edi.sign"
  'out_file = "C:\incoming\SALE-NO-NA100249-5958_1.edi.sign"
  Open in_file For Binary Access Read As #1
  Open out_file For Binary Access Write As #2
  For i =1 To 45 'skip 45 chars
    Get #1, ,buf
  Next
  While True  'skip all CR & LF after 45 chars
    Get #1, ,buf
    If buf >= 20 Then
      Put #2, ,buf
      Exit While
    End If
  Wend
  While Not EOF(1)
    Get #1, ,buf
    Put #2, ,buf
  Wend
  Close #1
  Close #2
End Sub
This script copies the original file and cuts 45 chars from header.
I've sent the example via email.
Of course this task requires BASIC plugin for RoboTask.
Download it here
Gekseppe
Edit a text file
Post by Gekseppe »
Ouch !!! I'm currently using version 3.1 of Robo Task and Basic Plugin seems to work with version >= 4.1
Do you think there's a way to overcome this ?
Many thanks
Edit a text file
Gekseppe
Edit a text file
Post by Gekseppe »
As usual great support !
Many thanks for your appreciated help: now I just get what I needed !
