macros - absolute cursor posn
Archaismic
Post by Archaismic »
can you record macros in absolute mouse position?  it makes it retarded difficult to modify a script/macro if everything is in reletive
Macro recorder catches mouse actions with parameters of windows and window elements.
On the other hand the using of absolute coordinates may be useful in some cases. I wrote that into our ToDo.
Archaismic
Oleg wrote:... the using of absolute coordinates may be useful in some cases. I wrote that into our ToDo.
:: cheers ::i just went back and edited all the movements to absolute... just sucks taking an extra hour of "coding" to make it so it's editable
