Just a basic question for all !
ahmed
Post by ahmed »
Hi !I just try Robotask and I do'nt know how to do this :1) Put automatically a text (a UserName and a Password) in a Dialog Box (a small connexion window) of my program.2) Validate automatically with OK ButtomCould you please tell me how to do that ? I create a task that opens the program and set the cursor in the right place ... but no more !Thank you for your answer.Best regards
Use Send keystroke action
The keystroke will be like this:
UserName{TAB}Password{Enter}
