A simple question !
ahmed
A simple question !
Post by ahmed »
Hi !I just discover ROBOTASK.Can you please tell me if it can do this :1) Run a Windows program (MDI sheet)2) Connect to the programm with a user Name and Password3) Choose a menu4) Do some mouse click5) And stop the programThank you for your answer !
A simple question !
Yes, of course.
Look at the following actions:
- Run program/Open document
- Send keystrokes
- Mouse actions
Also, the task editor contain macro recorder to record the series of mouse actions.
But there are some restrictions: System ignore keystrokes and mouse in locked or system session (this is the property of system).
