modify / split text lines
rice1973
Post by rice1973 »
Hi Oleg,I have to "modify" text lines in a CSV like this;CPRI,1112,4865,4866,4867,4868,4869should be tranformed to;
Normal
0
21
false
false
false
NL
X-NONE
X-NONE
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-s ize:0;
mso-style-noshow:yes;
mso-style-priority:99;
ms o-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001 pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
fon t-family:"Calibri","sans-serif";
mso-ascii-font-family:Cal ibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-f amily:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bid i-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;
mso-fareast-lang uage:EN-US;}
CPRI,1112,4865CPRI,1112,4866CPRI,1112,4867CPRI,1112,4868CPRI,1112,4869Is that possible?Best regards,Maurice
Suppose we have variable
MyVar
contained the text
Thus the required text will be such:
{MyVar(0)},{MyVar(1)},{MyVar(2)}
{MyVar(0)},{MyVar(1)},{MyVar(3)}
{MyVar(0)},{MyVar(1)},{MyVar(4)}
{MyVar(0)},{MyVar(1)},{MyVar(5)}
{MyVar(0)},{MyVar(1)},{MyVar(6)}
rice1973
Post by rice1973 »
Hi Oleg,It has mutiple, different textlines and can be between 1 and 10 varies long (after the first two values in the example "CPRI,1112" and "CPRI,1115");CPRI,1112,4865,4866,4867,4868,4869CPRI, 1115,5212,1515,2525,3626,2425,2625,1234,5678,4569,1258should be tranformed to;CPRI,1112,4865CPRI,1112,4866CPRI,1112,4867CPRI,1112,4868CPRI,1112,4869CPRI, 1115,5212CPRI, 1115,1515CPRI, 1115,2525CPRI, 1115,3626CPRI, 1115,2425CPRI, 1115,2625CPRI, 1115,1234CPRI, 1115,5678CPRI, 1115,4569CPRI, 1115,1258Please advice
Hm...
See the example below. It can parse dynamic string:
CatID=INTEGER|1380072790
ExternalName=STRING|"Task948"
ID=INTEGER|45935470
LocalVariables=STRING|"MyVar,cnt,DestText"
Name=STRING|"modify / split text lines"
Name=STRING|"Set variable ""MYVAR"" with value ""CPRI,1115,5212,1515,2525,3626,2425,2625,1234,5678,..."""
varname=STRING|"MYVAR"
 varvalue=STRING|"CPRI,1115,5212,1515,2525,3626,2425,2625,123 4,5678,4569,1258"
Name=STRING|"Simple Loop"
begin=STRING|"2"
end=STRING|"15"
variable=STRING|"CNT"
operator=STRING|"8"
value1=STRING|"{MyVar({cnt})}"
Name=STRING|"Set variable ""DESTTEXT"" with value ""{destText}{MyVar(0)},{MyVar({1})},{MyVar({cnt})}{E..."""
varname=STRING|"DESTTEXT"
 varvalue=STRING|"{destText}{MyVar(0)},{MyVar({1})},{MyVar({c nt})}{EOL}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Break"
Name=STRING|"Show ""{destText}"""
msg0=STRING|"{destText}"
rice1973
Post by rice1973 »
Hi Oleg,Sorry for late reply, was on a exhibition.I can't get the job done.... Can you help me out more?Just send you an email.
