UNIX timestamp
rice1973
UNIX timestamp
Post by rice1973 »
Hi Oleg,Is it possible to transform from "date / time" to "UNIX timestamp"?Example;"Sep  5 2010 11:47PM" should be converted to "1283723220
"Please advice.Best regards,Maurice
UNIX timestamp
I have found the algorithm of conversion of date-time to UNIX, but I got another result.
"Sep 5, 2010 11:47PM" should be converted to 1283730420.
Check it, please, carefully.
You should use Evaluate action with expression:
(cdbl(#09/05/2010 11:47PM#) - 25569)*24*60*60
Also see the example, which can convert any datetime value:
CatID=INTEGER|435362470
ExternalName=STRING|"Task674"
ID=INTEGER|910626022
LocalVariables=STRING|"aaa,dt"
Name=STRING|"Datetime to Unix1"
Name=STRING|"Input Box"
password=STRING|"0"
prompt=STRING|"Input the date-time"
variable=STRING|"DT"
Name=STRING|"Evaluate"
expression=STRING|"(cdbl(cdate(""{dt}"")) - 25569)*24*60*60"
variable=STRING|"AAA"
Name=STRING|"Show ""{aaa}"""
msg0=STRING|"{aaa}"
rice1973
UNIX timestamp
Post by rice1973 »
Hi Oleg,Imported task looks weird????Can you look??Best regards,Maurice
UNIX timestamp
You should copy only text in "code" section and save it as *.tsk file. Next you can import it.
I've tried this, everything is OK.
I can send this task to you via email, if it's necessary.
rice1973
UNIX timestamp
Post by rice1973 »
Hi Oleg,Still error see rar file for task en error message.http://www.sooco.nl/Robotask/Robotask.rarBest regards,Maurice
UNIX timestamp
The task is correct. It uses Basic plugin. I thought that you have Basic already installed.
download and install it here
It's free.
If you want to make some complex or non-standard calculations, it's better to make this on Basic.
