Cyclic Question
sunstrip
Cyclic Question
Post by sunstrip »
I have my task set up to repeat itself (cyclic mode)...but how do I set it to only repeat the task, say, 15 times and then stop ?
To give you an idea of what I'm doing here...is I have a PO form created in Word that has a macro attached so that each time you open the document the PO number increases by one...hence the reason that I have RoboTask set to open and print the document in the cyclic mode....that way I don't have to sit there and manually open/print/close over and over..I just want to set the program to run and repeat itself 50 times....by the way the is app is a Godsend for me...thanks !!!!
sunstrip
Cyclic Question
Post by sunstrip »
WOW....66 views and still no responce....this must be a tuff one !!!
Cyclic Question
Why do you not want to use simple loop?
Algorithm is simple:
simple loop from 1 to 15
   do something
end loop
2-nd way:
   Start another_task and wait for finish
end loop
Each task can be started only once at a time. But you can start another task
sunstrip
Cyclic Question
Post by sunstrip »
Will give it a shot....thanks !!!
