Run Program/Open Document Task Not Working
elwayfan446
Re: Run Program/Open Document Task Not Working
Post by elwayfan446 »
Oleg,
Your software has been vetted and approved by my company so I don't think antivirus would be blocking it. I tried to run c:\windows\sysnative\cmd.exe and I got the message that the file couldn't be found. This is so puzzling.
elwayfan446
Oleg wrote:One more thing:
RoboTask is 32-bit application. It can work under x64 system without problems but several restrictions exist.
If you try to run CMD.EXE then system runs 32-bit version of CMD from C:\Windows\SysWOW64\CMD.EXE
When you try to run c:\windows\system32\cmd.exe system runs C:\Windows\SysWOW64\CMD.EXE too (!!!)
To run x64 version of CMD.EXE use command line
It this case system runs the native x64-bit version of CMD.EXE from C:\Windows\System32\CMD.EXE
It most cases there are not matter what version is working. But sometimes it is critical.
Try this trick with sysnative virtual folder
In this case full command line will be:
c:\windows\sysnative\cmd.exe /c your_cmd_file
Hi Oleg,
I am back trying to get my .cmd file to run from RoboTask and I am revisiting this suggestion. I am not sure I am plugging this into the task box right. Can you send a screenshot on how I can call the .cmd file this way?
Thanks,
Scott
Look at this example
CatID=INTEGER|263000617
ExternalName=STRING|"Task156"
ID=INTEGER|195597699
Name=STRING|"sysnative"
Name=STRING|"Run ""cmd.exe """
ifnonzero=STRING|"0"
program=STRING|"c:\windows\sysnative\cmd.exe"
runas=STRING|"0"
wait=STRING|"0"
if you need to run some command line look at this:
ExternalName=STRING|"Task159"
ID=INTEGER|-1475315895
Name=STRING|"sysnative 2"
ActionID=STRING|"A_MISC_RUNCONSOLEAPP"
Name=STRING|"Run command-line utility: cmd.exe /c echo put here some command line"
convertansi=STRING|"0"
outputvar=STRING|"out"
params=STRING|"/c echo put here some command line"
saveexitcode=STRING|"0"
saveoutput=STRING|"1"
Name=STRING|"Show ""{out}"""
msg0=STRING|"{out}"
Both tasks work on Windows 10 x64 without problem
elwayfan446
Finally! I got this to work. It has been a long road but I am glad it is working. Thank you for all of your help.
