Reactivation of tethering software on disconnect
Re: Reactivation of tethering software on disconnect
... but the menu that pops up shows on some other part of the screen instead of down by the Systray where ...
RoboTask doesn't control menu of external program. Maybe this is the behavior of your application...
I tried to create similar task. It open Viber interface from systray. It works fine
Look at my example example
ExternalName=STRING|"Task1180"
ID=INTEGER|-1088526321
Name=STRING|"Open Viber application"
ActionID=STRING|"A_FINDBYIMAGE"
Name=STRING|"Find an Element by Image"
generror=STRING|"1"
img00000000=STRING|"eNpz8g1iYwADMyDWAGIxIBYHYkYGCbC4DFQeGVjrydroyQJJK10ZayACs61R2ZY60kAEUqkvZwOX1ZU"
img00000001=STRING|"BarHSkQabgdABI63ADKAOZLOtYOJAfUCGDcwGoBlgJTYQ10BUwXWA1cKthJCW2lKWcHGwMQwMcFVwRw"
img00000002=STRING|"CVJDhZxjiYQd0E1IFkGNRCsBOtEX6ByEP9CpYp8nXbUFAeZW+C7G9rmAdt4FrArmdgQPY0SB7MrQ7y2"
img00000003=STRING|"1pcvaGgrDrYvzLQt9TPI93d3t9SxwZboAP9ArMAYpKzkXJPTPTmokqgGZhoRU5hvrcrInjAesHhAfWx"
img00000004=STRING|"jrSdvtz8tCxMrftauq9u3AokIdwyfy8bpOgD+gUpfWS6O6Dp3lXT/ODoiT8/f/7////rm7c7qpqAguv"
img00000005=STRING|"zy+wNFOBOgacPcGD1xsQgG3Cod8q3d+9/fv329/cfoBmvb97eXlEPkYp1soDHI8QvsPCYl5oJN+Bg18"
img00000006=STRING|"SfX74+OHJ8Z03zmflLrq7fsq2sDi6b7ekED0KkNAYUWJSRA1Gyvbzuw6MnL69eR/PattJaCKPIxx3JD"
img00000007=STRING|"EhoQvyyEGbG5bWbgI4/u2g5XPfZhcvOLVpxccVaCLfc3wuaaBBxC/HRzORUkCPK6r68fgM04/OLlxCL"
img00000008=STRING|"j0+d/fjU2Tt7DhybOhtiRq6XMzyzwsIUEiQdkRFA+T0N7ZCIeHjsFJC7u77t5vbdRyfNeHn1BtxZcY4"
img00000009=STRING|"W0OQOzS82sJSf6moDUXJy1oKnZy/sqGoE+WLBsidnzj+7cGlHZSNEFhi3dvryVrCMgxovdnpy81Iz0M"
img0000000A=STRING|"Jxb3PXnsYOZJG64EDkXA2JFz1ZW1hOcjdR64+N21JUhTWtA11QHeRvqy+PXNLA8r4NvIwCm+RhopbmY"
img0000000B=STRING|"lMT5N8UFtwaEQa0uNTPE5iuHAwUMMs6ePkBFwYz4CGEyPswBE3U8OITHC8wMRuYbmQHQTyNaQYCQf2C"
img0000000C=STRING|"bChKiYihFREBSGrA7rCBGQr3ghWsjEI4BewvZAXwgGRgAADUbecC"
imgcount=STRING|"13"
posx=STRING|"11"
posy=STRING|"11"
putcursor=STRING|"1"
saveresult=STRING|"0"
startx=STRING|"1862"
starty=STRING|"1040"
Name=STRING|"Click right button"
action=STRING|"0"
button=STRING|"1"
Name=STRING|"Delay 200 ms"
delay=STRING|"200"
dimension=STRING|"0"
ActionID=STRING|"A_MOUSE_MOVE"
Name=STRING|"Move"
dx=STRING|"0"
dy=STRING|"15"
mode=STRING|"1"
delay=STRING|"200"
Name=STRING|"Click left button"
action=STRING|"0"
button=STRING|"0"
... but the menu that pops up shows on some other part of the screen ...
It this case use Find an Element by Image action to find necessary menu item on the screen
xyberz
Post by xyberz »
I think I'll do a screen recording so you can see exactly what's happening so you can get a better idea of what's happening when I add in those extra move and click commands and post it on YouTube.
