Task status email notifications
elwayfan446
Re: Task status email notifications
Post by elwayfan446 »
Here you go. Thanks, Oleg.
RoboTask.zip
(5.58 KiB) Downloaded 1300 times
This is the system log of RoboTask. I need the full log of your task.
Each task has its own log file
elwayfan446
Oleg, I have looked through all of the logs in the log folder and I don't see any logs other than the basic job status logs. Am I looking in the right place? Please point me where to get the log for you.
How to find log folder (see screenshot below)
of course you have to enable log file for this task:
elwayfan446
Yes, that is the folder I was looking at. Nothing in the logs that went into detail about the error.
I have already fixed the issue from the other day. I will try to reproduce it later and then send you all of the logs in the folder once I do.
jherbstreit
Post by jherbstreit »
When I enter multiple email addresses into the Robotask Command 'Email Success Notification' the task errors out and states the below:
Error occurred: Unable to relay <CR><LF>
I only successfully receive my notification emails if 1 address is listed - regardless if it's in the TO, CC, or BCC line...Only 1 address works. How do I use multiple email addresses?
Thank you!
Jayme
You can specify many addresses in fields TO, CC, or BCC
Just enumerate these addresses separated with commas (,) or semicolons (;)
For example:
user1@domain1.com;user2@domain2.com; user3@domain3.com; user4@domain4.com
You can specify addressees with real names:
"John Smith"<user1@domain1.com>;"Piter Penn"<user2@domain2.com>;"Melissa Smart"<user3@domain3.com>;"Accounting"<user4@domain4.com>;
