Renaming Files Automation
DSTP
Re: Renaming Files Automation
Post by DSTP »
Thanks for the helping me with this, however it's not changed any of the file names.
I've changed the base folder to the folder containing the images.
Imported task.
Run the program.
It finds the excel file.
Program runs through process.
Finished with no errors.
No file names have changed.
Please help!!
I tested this example on real files. It works. But I made some corrections.
see task below:
CatID=INTEGER|1416408852
ExternalName=STRING|"Task9"
ID=INTEGER|263140533
Name=STRING|"Example for Excel"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Change Folder (c:\basefolder)"
folder=STRING|"c:\basefolder"
Name=STRING|"Break"
Name=STRING|"STR Replace"
[Actions\Action12\Params]
mode=STRING|"0"
replacement=STRING|"\"
source=STRING|"{oldname}"
substring=STRING|"/"
variable=STRING|"oldname"
[Actions\Action13\Params]
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"{oldname}{eol}{newname}"
position=STRING|"3"
title=STRING|"aaa"
width=STRING|"330"
[Actions\Action14]
Name=STRING|"Rename File"
[Actions\Action14\Params]
file0=STRING|"{OldName}"
ifexists=STRING|"0"
mask=STRING|"{ValidFileName({NewName})}.*"
subdirs=STRING|"0"
[Actions\Action15]
filename=STRING|"C:\Temp\downloads\Robotask.xlsx"
hide=STRING|"0"
mode=STRING|"0"
Name=STRING|"Create local variable ""ROW"" with value ""1"""
varname=STRING|"ROW"
varvalue=STRING|"1"
Name=STRING|"While loop"
value1=STRING|"true"
Name=STRING|"Increment variable ""row"""
incement=STRING|"1"
vaiable=STRING|"row"
Name=STRING|"Set variable ""OLDCELL"" with value ""R{row}C3"""
varname=STRING|"OLDCELL"
varvalue=STRING|"R{row}C3"
Name=STRING|"Set variable ""NEWCELL"" with value ""R{row}C2"""
varname=STRING|"NEWCELL"
varvalue=STRING|"R{row}C2"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"{OldCell}"
cell00000001=STRING|"{newCell}"
count=STRING|"2"
var00000000=STRING|"oldName"
var00000001=STRING|"NewName"
worksheet=STRING|"sheet1"
operator=STRING|"7"
value1=STRING|"{OldName}"
Pay attention that you have several errors in you EXCEL files
1. Old file name is invalid: l/071/product_80552_1_orig__18669.jpg
you use symbol "/" instead of "\". See step #12. it makes changes.
2. You use illegal symbols in new filenames.
For example the name lavender_star_foil_balloon_19"_15537 contains the quote char ". It is illegal symbol in file names
I use {ValidFileName({NewName})} variable. It removes invalid characters. See step #14
I created base folder with subfolders and files you specified in excel file and tested the task. It works.
Base folder is C:\basefolder
full folder structure before executing the task:
Folders:
C:\basefolder\l
C:\basefolder\l\071
C:\basefolder\l\086
C:\basefolder\l\095
C:\basefolder\l\114
C:\basefolder\l\117
C:\basefolder\l\119
C:\basefolder\l\124
C:\basefolder\l\134
C:\basefolder\l\136
C:\basefolder\l\149
C:\basefolder\l\150
C:\basefolder\l\159
C:\basefolder\l\160
Files:
Full folder structure after:
Folders:
C:\basefolder\l
C:\basefolder\l\071
C:\basefolder\l\086
C:\basefolder\l\095
C:\basefolder\l\114
C:\basefolder\l\117
C:\basefolder\l\119
C:\basefolder\l\124
C:\basefolder\l\134
C:\basefolder\l\136
C:\basefolder\l\149
C:\basefolder\l\150
C:\basefolder\l\159
C:\basefolder\l\160
Files:
C:\basefolder\l\071\under_the_sea_fish_cutouts_35.6cm_18015
C:\basefolder\l\114\nautical_flag_picks-6.4cm__pack_50__14829
C:\basefolder\l\124\blue_solid_colour_table_skirting_70cm_4.2m_17145
