Rename folders
Rename folders
You should get the list of folders first.
Next you should sort the folder list in descending order .
At last rename folders in the text loop
See the example below:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task69"
ID=INTEGER|150137837
Name=STRING|"rename folders 3"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Name=STRING|"Create local variable ""OLDPATHNAME"" with value """""
varname=STRING|"OLDPATHNAME"
Enabled=INTEGER|0
Name=STRING|"Break"
Name=STRING|"Text Loop"
destvar=STRING|"OLDPATHNAME"
line0=STRING|"{text}"
sourcetext=STRING|"1"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
[Actions\Action12\Params]
from=STRING|"1"
search=STRING|"-"
source=STRING|"{ExtractFileName({OldPathName})}"
variable=STRING|"APos"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
[Actions\Action13\Params]
amount=STRING|"{APos}"
from=STRING|"1"
variable=STRING|"NewPathName"
[Actions\Action14]
[Actions\Action14\Params]
operator=STRING|"1"
value1=STRING|"{ExtractFileName({OldPathName})}"
value2=STRING|"{NewPathName}"
[Actions\Action15]
[Actions\Action15\Params]
message=STRING|"File {OldPathName} is renaming to {NewPathName}"
[Actions\Action16]
ActionID=STRING|"A_FOLDER_RENAME"
Name=STRING|"Rename Folder ""{OldPathName}"""
[Actions\Action16\Params]
folder=STRING|"{OldPathName}"
newfolder=STRING|"{NewPathName}"
[Actions\Action17]
[Actions\Action18]
Name=STRING|"Create local variable ""NEWPATHNAME"" with value """""
varname=STRING|"NEWPATHNAME"
Name=STRING|"Create local variable ""APOS"" with value """""
varname=STRING|"APOS"
Name=STRING|"Create local variable ""TEXT"" with value """""
varname=STRING|"TEXT"
Name=STRING|"File Loop"
date1=STRING|"20100105"
date2=STRING|"20100105"
DuringMinutes=STRING|"1"
file0=STRING|"D:\3dmap\*.*"
searchkind=STRING|"1"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{OldPathName}{eol}"""
varvalue=STRING|"{Text}{OldPathName}{eol}"
ActionID=STRING|"A_FILE_SORTTEXT"
Name=STRING|"Sort Text"
assignvar=STRING|"1"
line00000000=STRING|"{text}"
savetofile=STRING|"0"
sortmode=STRING|"1"
sourcekind=STRING|"1"
variable=STRING|"text"
Enabled=INTEGER|0
Name=STRING|"Show ""{text}"""
msg0=STRING|"{text}"
rice1973
Rename folders
Post by rice1973 »
Works!
