Rename folders
rice1973
Rename folders
Post by rice1973 »
Hello Oleg,
I need to rename folders.
eg "12532-123.10.236" has to become "123.10.236"
eg "1254-152.23.252" has to become "152.23.252"
Under is the task for renaming files like that. How can i
use it to rename the folders?
CatID=INTEGER|1190029287
ExternalName=STRING|"Task3"
ID=INTEGER|1601804429
Name=STRING|"rename files"
Name=STRING|"File Loop"
date1=STRING|"20100105"
date2=STRING|"20100105"
destvar=STRING|"OLDFILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\3dmap\*.swf"
searchkind=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{ExtractFileName({OldFileName})}"
variable=STRING|"APos"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"{APos}"
from=STRING|"1"
variable=STRING|"NewFileName"
Name=STRING|"STR Replace"
mode=STRING|"0"
source=STRING|"{NewFileName}"
substring=STRING|"-000"
operator=STRING|"1"
value1=STRING|"{ExtractFileName({OldFileName})}"
value2=STRING|"{NewFileName}"
message=STRING|"File {OldFileName} is renaming to
{NewFileName} ..."
Name=STRING|"Rename File"
file0=STRING|"{OldFileName}"
ifexists=STRING|"0"
mask=STRING|"{NewFileName}"
subdirs=STRING|"0"
Rename folders
You can't use this task without changes.
You should modify this task (or create new task and use this task as template):
- File loop mus be "By folders"
- It seems step #4 is superfluous
- Use "rename folder" instead of "rename files"
rice1973
Rename folders
Post by rice1973 »
Mmmh,
Almost good, but not working.
Can you look?
CatID=INTEGER|0
ExternalName=STRING|"Task4"
ID=INTEGER|150137837
Name=STRING|"rename folders 2"
destvar=STRING|"{NEWPATHNAME}"
file0=STRING|"D:\3dmap\*.*"
searchkind=STRING|"1"
subdirs=STRING|"0"
timesize=STRING|"0"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{ExtractPathName({OldPathName})}"
from=STRING|"1"
variable=STRING|"NewPathName"
Params=FOLDER[Root]
item0003=STRINGLIST
item0004=STRINGLIST
item0005=STRINGLIST
item0006=STRINGLIST
item0007=STRINGLIST
item0008=STRINGLIST
item0009=STRINGLIST
item0010=STRINGLIST
item0011=STRINGLIST
[\item0003]
s1=[General]
s2=ActionId=A_LOOP_FILE
s3=Name=File Loop
s4=Enabled=-1
s5=[Params]
s6=searchkind=1
s7=filecount=1
s8=file0=D:\3dmap\*.*
s9=subdirs=0
s10=destvar={NEWPATHNAME}
s11=createmode=1
s12=date1=20100105
s13=date2=20100105
s14=DuringMonths=1
s15=DuringDays=1
s16=OlderMonths=1
s17=OlderDays=1
s18=DuringHours=1
s19=DuringMinutes=1
s20=OlderHours=1
s21=OlderMinutes=1
s22=WithoutPath=0
s23=savesize=0
s24=timesize=0
[\item0004]
s1=[General]
s2=ActionId=A_STR_POS
s3=Name=STR Pos
s4=Enabled=-1
s5=[Params]
s6=source={ExtractPathName({OldPathName})}
s7=search=-
s8=case=0
s9=from=1
s10=variable=APos
[\item0005]
s1=[General]
s2=ActionId=A_STR_DELETE
s3=Name=STR Delete
s4=Enabled=-1
s5=[Params]
s7=from=1
s8=amount={APos}
s9=variable=NewPathName
[\item0006]
s1=[General]
s2=ActionId=A_STR_REPLACE
s3=Name=STR Replace
s4=Enabled=-1
s5=[Params]
s6=source={NewPathName}
s7=substring=-000
s8=case=0
s9=mode=0
s10=variable={NEWPATHNAME}
[\item0007]
s1=[General]
s2=ActionId=A_FLOW_IF
s3=Name=If Then
s4=Enabled=-1
s5=[Params]
s6=type=0
s7=value1={ExtractPatName({OldPathName})}
s8=operator=1
s9=value2={NewPathName}
s10=case=0
[\item0008]
s1=[General]
s2=ActionId=A_ROBOTASK_LOG
s3=Name=Log Message
s4=Enabled=-1
s5=[Params]
s6=message=File {OldPathName} is renaming to
{NEWPATHNAME} ...
s7=type=3
[\item0009]
s1=[General]
s2=ActionId=A_FILE_RENAME
s3=Name=Rename File
s4=Enabled=-1
s5=[Params]
s6=count=1
s7=file0={OldPathName}
s8=mask={NewPathName}
s9=subdirs=0
s10=ifexists=0
[\item0010]
s1=[General]
s2=ActionId=A_FLOW_ENDIF
s3=Name=End If
s4=Enabled=-1
s5=[Params]
[\item0011]
s1=[General]
s2=ActionId=A_LOOP_END
s3=Name=End Loop
s4=Enabled=-1
s5=[Params]
mode=STRING|"0"
source=STRING|"{NewPathName}"
variable=STRING|"{NEWPATHNAME}"
operator=STRING|"1"
value1=STRING|"{ExtractPatName({OldPathName})}"
value2=STRING|"{NewPathName}"
message=STRING|"File {OldPathName} is renaming to
{NEWPATHNAME} ..."
file0=STRING|"{OldPathName}"
ifexists=STRING|"0"
mask=STRING|"{NewPathName}"
subdirs=STRING|"0"
Rename folders
I'm sorry this is a mishmash with text of the task and steps from clipboard...
Why do you use OldPathName variable in steps #2, 3, 5, 6, 7
I don't see where you assign some value to it
Maybe you want to save the value into OldPathName in step #1
Also see step #1. You do not need use braces "{}".
Write variable name only.
rice1973
Rename folders
Post by rice1973 »
Hello Oleg,
See the Task you made for the files;
http://www.robotask.com/forum/forum_posts.asp?
TID=933&KW=rename+files
This one i need for folders.
Rename folders
See the example below:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task69"
Name=STRING|"rename folders 3"
Name=STRING|"Create local variable ""OLDPATHNAME"" with value """""
varname=STRING|"OLDPATHNAME"
Name=STRING|"Create local variable ""NEWPATHNAME"" with value """""
varname=STRING|"NEWPATHNAME"
Name=STRING|"Create local variable ""APOS"" with value """""
varname=STRING|"APOS"
destvar=STRING|"OLDPATHNAME"
subdirs=STRING|"0"
timesize=STRING|"0"
from=STRING|"1"
search=STRING|"-"
from=STRING|"1"
operator=STRING|"1"
message=STRING|"File {OldPathName} is renaming to {NewPathName}"
ActionID=STRING|"A_FOLDER_RENAME"
Name=STRING|"Rename Folder ""{OldPathName}"""
folder=STRING|"{OldPathName}"
newfolder=STRING|"{NewPathName}"
rice1973
Rename folders
Post by rice1973 »
Mmh, almost OK.
When i run the task it transforms "11444-388.30.025" in to
"388.30.025)}" ?? Strange isn't it?? :S
Rename folders
You should replace ExtractPathName to ExtractFileName everywhere
ExtractPathName - is nonexistent variable.
Or simply use the example below:
subdirs=STRING|"0"
timesize=STRING|"0"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{ExtractFileName({OldPathName})}"
from=STRING|"1"
operator=STRING|"1"
value1=STRING|"{ExtractFileName({OldPathName})}"
rice1973
Rename folders
Post by rice1973 »
Thanx!!
rice1973
Rename folders
Post by rice1973 »
Oeps, to early..
In the mainfolder eg "11641-286.65.001"
is a subfolder "Images" and in that folder the is another
subfolder "11641-286.65.001" that also has to be renamed
to "286.65.001"
So original structure is "11641-286.65.001/Images/11641-
286.65.001" has to become "286.65.001/Images/286.65.001"
The Include Subfolders in File Loop does
not work.
I think that is not working because of Create local
variable
Any solution?
