How to convert string to integer
artyom
Post by artyom »
Hello. I use RoboTask Lite and I have a question: how can i convert string variable (content of the clipboard {ClipBoardContent} ) to integer, so i can increase or decrease it?
Re: How to convert string to integer
Look at the example below:
CatID=INTEGER|0
ExternalName=STRING|"Task14"
ID=INTEGER|567220487
Name=STRING|"1 test clipboard"
Name=STRING|"Put Text"
line0=STRING|"22"
sourcetext=STRING|"1"
Name=STRING|"Show ""Decremented"""
msg0=STRING|"Decremented"
msg1=STRING|"{ClipBoardContent}"
msgcount=STRING|"2"
Name=STRING|"Show ""Original"""
msg0=STRING|"Original"
msgcount=STRING|"2"
Name=STRING|"Get Text"
variable=STRING|"num"
incement=STRING|"1"
vaiable=STRING|"num"
line0=STRING|"{num}"
Name=STRING|"Show ""Incremented"""
msg0=STRING|"Incremented"
msgcount=STRING|"2"
incement=STRING|"-2"
Any variables of RoboTask are strings
You do not need to convert them. RoboTask make necessary transformations itself, if it's possible.
artyom
Post by artyom »
Oleg wrote:Any variables of RoboTask are strings
Thank you for help! Your example was very helpfull ))))
