<< Click to Display Table of Contents >> Navigation: Actions > Registry > Registry loop |
The action allows you to enumerate keys or values from the registry.
Key name
The start key name. You can use the dialog box to select the key interactively. To open it click the button to the right of the text box.
With subkeys
If you want to process all sub-keys recursively switch on this checkbox
Loop kind
There are two options
•Loop by registry values
•Loops by keys only
Save values as
You can save values of the loop in separate variables or in one variable as JSON
