<< Click to Display Table of Contents >> Navigation: Actions > Regular Expressions > RegExp COM object |
RegExp COM object is designed for using in Basic script.
Object name: RegExpCOM.RegexpClass
Object GUID: ['{0762F9AA-BD80-4BFC-B469-854866F114CC}']
Example of using
Below is an example of using RegExp COM object in Basic script
Sub Main
Dim obj As Object
Dim i As Long
Dim cnt As Long
Dim res As Boolean
Dim s As String
Set obj = CreateObject( "RegExpCOM.RegexpClass" )
obj.Subject = RoboTaskApp.ExpandText("{txt}")
obj.RegExp = RoboTaskApp.ExpandText("{regex}")
res = obj.Match
While res
cnt = obj.SubExpressionCount
s = ""
For i = 0 To cnt
s = s + obj.SubExpression( i ) + Chr(10)
Next i
MsgBox( s )
res = obj.MatchAgain
Wend
End Sub
Also you can make permanent link to RegExpCOM Library in the script. In this case you should declare the object so:
And create the object by using New directive
Set obj = New RegExpClass
Members of object
Anchored
Read-Write property, type – Boolean
Get or set anchored mode of object.
Caseless
Get or set case insensitive mode of object.
Extended
Get or set extended mode of object.
Match
Read-only property, type – Boolean
Find first match. Returns TRUE if expression was found.
MatchAgain
Find next match. Returns TRUE if expression was found.
Multiline
Get or set multiline mode of object.
NoAutoCapture
Get or set NoAutoCapture mode
RegExp
Read-Write property, type – String
Get or set regular expression.
Replace
Read-only property, type - String
It replaced found expression by "replacement" and returns new expression.
This property can be used only after successful Match or MatchAgain.
ReplaceAll
Read-only property, type – Long
Replace all matches. Returns the number of replacements.
Replacement
The replacement string. Used in Replace and ReplaceAll.
SingleLine
Get or set single line mode of object.
SubExpression(ByVal idx as Long)
Read-only property, type- String
Returns sub-expression by index.
SubExpressionCount
Read-only property, type- Long
Returns the number of sub-expressions.
SubExpressionLength(ByVal idx as Long)
Returns the length of sub-expression by index.
SubExpressionOffset(ByVal idx as Long)
Returns the offset (position) of sub-expression by index.
Subject
Get or set the text to process.
Ungreedy
Get or set un-greedy mode of object.
