read control content
mikronos
Post by mikronos »
Hello,the "Move To Object" function is very powerfull, but after that, is there a way to read the content of the control and put it into a variable? (without using a basic script, but only integrated command)Thanks for response.
You can read the text without problems only from edit fields or simple text input fields. Most controls hides own content from program interface.
I wrote this wish into our ToDo list.
mikronos
Post by mikronos »
Thanks for response Oleg:)
