Rename content of a text fil
rice1973
Post by rice1973 »
Hi Oleg,Is it possible to replace text "in" a text file?Example;file:test.txtIn the file the is a "." that needs to be replaced by ",".Best regards,Maurice
Yes of course.
use STR Replace action.
put
{TextFile(Test.txt)}
into source string
and write result into NewText variable (for example)
Next step - Write Text File
use expression
{NewText}
as text.
rice1973
Post by rice1973 »
Hi Oleg,
Can you help me with a task file?
See example below, please:
CatID=INTEGER|1380072790
ExternalName=STRING|"Task916"
ID=INTEGER|1703573345
LocalVariables=STRING|"filename,text"
Name=STRING|"replace (.) to (,)"
Name=STRING|"Set variable ""FILENAME"" with value ""C:\incoming\test.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"C:\incoming\test.txt"
Name=STRING|"STR Replace"
mode=STRING|"0"
replacement=STRING|","
source=STRING|"{TextFile({FileName})}"
substring=STRING|"."
variable=STRING|"text"
Name=STRING|"Create text file {FileName}"
fileexists=STRING|"0"
filname=STRING|"{FileName}"
line0=STRING|"{text}"
suppress=STRING|"1"
