count rows in a text file.
johanmartens
Post by johanmartens »
Hi
Is there a way to count how many rows there is in a text file?
Best regards and thanks.
You have to use Text Loop action.
Algorithm is simple:
set variable LineCount to 0
text loop
   inctement variable LineCount by 1
end loop
after the loop you get the number of lines of the text. If you get 0, this means that text is empty.
jonjon
Post by jonjon »
Thanks for answer, it works perfect.
