Out of Memory
uniekaas
Out of Memory
Post by uniekaas »
We use Robotask to perform multiple tasks and every few weeks we encounter an error which causes Robotask tasks to stop. The error message is "out of memory". '
It runs on a virtual server with 512 MB of memory which should be sufficient. After a reboot the program can run it's taks again.
Out of Memory
What operating system on your virtual machine?
What version of RoboTask do you use?
How many tasks have you created?
You may answer directly to my email (oleg (at) robotask . com)
Also, it would be great if send me the set of your tasks and all log files.
uniekaas
Out of Memory
Post by uniekaas »
It's running on a Virtual pc 2007 with Windows XP SP2 32bit installed on it. Current version is 3.5.2 with 10 active tasks running.
mail sent.
