Robotask Updates
carroll
Robotask Updates
Post by carroll »
Problem with the updates screen.  This screen comes up every time I boot up my computer, even though I have it set to check every 7 days.  When I click on "close", I get the message - Cannot create    C:\programdata\robotask\updates.xml  Access is denied.
The only way I can get rid of the updates screen is to bring up the Windows Task Manager and click on "End Task"
Thanks  Carroll
Robotask Updates
This problem is appear under Windows Vista with a few user accounts on this computer.
I'm afraid that you have to remove updater data manually in order to solve the problem.
- Log on as administrator
- Go to C:\ProgramData\ folder. This is higgen folder and you may to enter the folder name manually in the addres line of windows explorer
- Remove the folder named RoboTask.
- Log off from administrator.
We already have fixed this problem in latest version and you may download it from our site.
