Browsing a folder?
Academic2008
Browsing a folder?
I'm a new user and am wondering what action allows you to browse a folder within Windows Explorer. For example,Open c:\data on the deskop[Folder opens, allowing me to open any subfolders as needed]I've looked extensively at the help files. The "open dialog" action only seems to work within applications. And the window produced by the "Browse folder" action doesn't allow me to open up any subfolders below the folder specified.There must be some action that I'm missing. I'm really excited about using this instead of AHK, and I'm hoping someone can help me figure this out.Best,Rachel
Browsing a folder?
Use the "Run Program/Open document" action.
Specify c:\data (or another folder) as a program/document name.
