need help
phenix
need help
Post by phenix »
hello! How can I display all new Files, which were downloaded from a ftp-server and than print them? Such a pop-up or so... (This is a regular synchronization; there are about 7 folders which must be recursively synchronized)
need help
You can do this by using "File monitor" triggering event
It can monitor the specified folder (folders) recursively and save the changes into text file: in one file or separately new files, changed files and deleted files.
See "Save changes" tab of event editor.
phenix
need help
Post by phenix »
So much so far I am getting started with it Another one question:Could I print the downloaded files automatically with this programm too?Thx.
need help
Yes, of course. Look at the "Print document" action
