Task that let you chose between other tsk
MainMan B
Post by MainMan B »
I would like to know if it's possible to create a task
that let you choose between tasks you have created
earlier, maybe even choose more than one. I hope you
understand what I mean.
Regards,
Rasmus Bertelsen
It's possible.
You may create the task with the following algorithm:
Input box // Input the number and save into NUM variable
if {NUM} = 1 then
   stert task task1
end if
if {NUM} = 2 then
   stert task task2
end if
if {NUM} = 3 then
   stert task task3
end if
... etc.
MainMan B
Post by MainMan B »
Should the: "if {NUM} = etc." statements be in the
variable you create, in the if then dialogue? I can't
seem to make it work.
Regards,
Rasmus Bertelsen
See the example below:
CatID=INTEGER|700197831
ExternalName=STRING|"Task700"
ID=INTEGER|370801753
Name=STRING|"Choose between"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Name=STRING|"Input Box"
default=STRING|"0"
prompt=STRING|"Type the number from 1 to 5"
variable=STRING|"NUM"
type=STRING|"1"
value1=STRING|"{num}"
value2=STRING|"4"
Name=STRING|"Show ""Here you may run the task #4"""
[Actions\Action12\Params]
msg0=STRING|"Here you may run the task #4"
[Actions\Action14]
[Actions\Action14\Params]
type=STRING|"1"
value2=STRING|"5"
[Actions\Action15]
Name=STRING|"Show ""Here you may run the task #5"""
[Actions\Action15\Params]
msg0=STRING|"Here you may run the task #5"
[Actions\Action16]
type=STRING|"1"
value2=STRING|"1"
Name=STRING|"Show ""Here you may run the task #1"""
msg0=STRING|"Here you may run the task #1"
type=STRING|"1"
value2=STRING|"2"
Name=STRING|"Show ""Here you may run the task #2"""
msg0=STRING|"Here you may run the task #2"
type=STRING|"1"
value2=STRING|"3"
Name=STRING|"Show ""Here you may run the task #3"""
msg0=STRING|"Here you may run the task #3"
Save the text of the task into file and use menu "Task | Import" in order to import into RoboTask
MainMan B
Post by MainMan B »
Cool! Thank you very much for that. I suppose the FOLDER
strings in the Action section should be my task names,
or the names of them with the .tsk extension?
