Global variables
meriturva
Global variables
Post by meriturva »
Any way to disable the global variable functionality?
We have some task and we just would like to don't care about the variable name between differrent tasks. Now we have to put attention on the name of variable if it is used on other tasks.
Meriturva
meriturva
Global variables
Post by meriturva »
no way?please just to know if it is possible to disable the global scope of variables!Meriturva
Global variables
All user variables are global within RoboTask. Each task can access them and change them.
If you want to guarantee that variable is been use only in one task you must use unigue names. For example use some specific prefix.
RichardBlank
Global variables
Post by RichardBlank »
Oleg wrote:All user variables are global within RoboTask. Each task can access them and change them.
Thank you Oleg. Helpful advice.
