Place text
degoup
Place text
Post by degoup »
I seek to replace a parameter in a file existing at a quite precise place. This one is in tenth line. I am able to put it in top or bottom but not at the good place
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|385352816
ExternalName=STRING|"Task3"
ID=INTEGER|1504975704
Name=STRING|"Create text file C:\Documents and Settings\ROUX\Bureau\TEST OK.txt..."
Name=STRING|"Create text file C:\Documents and Settings\ROUX\Bureau\Move_Print.ini"
fileexists=STRING|"0"
filname=STRING|"C:\Documents and Settings\ROUX\Bureau\Move_Print.ini"
line0=STRING|"{INSERT}"
line1=STRING|"{TEXTFILE(Move_Print.ini)}"
line2=STRING|"{INSERT}"
linecount=STRING|"3"
Place text
If you want to replace some specific line, you have to use text loop.
See example below.
Suppose user variable "INSERT" contains new line. The task replaces 10-th line of text to new line.
;* Do not edit!       *
CatID=INTEGER|1947094105
ExternalName=STRING|"Task518"
ID=INTEGER|47088364
Name=STRING|"replace 10-th line of the text"
Name=STRING|"Set variable ""LINE_NUM"" with value ""1"""
varname=STRING|"LINE_NUM"
varvalue=STRING|"1"
line0=STRING|"{new_text}"
Name=STRING|"Set variable ""NEW_TEXT"" with value """""
varname=STRING|"NEW_TEXT"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
file=STRING|"C:\Documents and Settings\ROUX\Bureau\Move_Print.ini"
linecount=STRING|"0"
sourcetext=STRING|"0"
type=STRING|"1"
value1=STRING|"{line_num}"
value2=STRING|"10"
Name=STRING|"Set variable ""NEW_TEXT"" with value ""{new_text}{insert}{Eol}"""
varvalue=STRING|"{new_text}{insert}{Eol}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Set variable ""NEW_TEXT"" with value ""{new_text}{c_line}{Eol}"""
varvalue=STRING|"{new_text}{c_line}{Eol}"
Name=STRING|"Increment variable ""line_num"""
incement=STRING|"1"
vaiable=STRING|"line_num"
degoup
Place text
Post by degoup »
Oleg,
Thanks very much, it's perfect......
I bought your soft yesterday, it's véry cool...
Dégoup
validator
Place text
Post by validator »
Oleg,
I tried the solution you suggested, but unfortunately it does not work like i want. Nothing from my txt file is copied in the specific of the program. For this line you must read :
"I tried the solution you suggested, but unfortunately it does not work like i want. Nothing from my txt file is copied in the specific "field" of the program.
