New version of RoboTask is ready for download. Download and try RoboTask 11.1 now
What's new in RoboTask 11.0:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
+ A new plugin has been added - PDF Toolkit. New actions:
+ PDF extract text
+ PDF extract images
+ PDF extract pages
+ PDF merge files
+ New variable {GetCurrentStep(<ID_or_external_Name>)}
+ Encryption methods supported by the modern ZIP format have been added to the "Zip Pack Files" action.
+ The export of the visible task list to a CSV file has been added.
+ Task highlighting (enabled/disabled) has been added to the task selection dialog, similar to the main window.
+ A visualisation of a task comment in a pop-up window has been added to the task list for local tasks.
+ Comments have been added to global variables. The comment is visible when you hover the mouse cursor over a variable in the variable selection window.
+ Default variable names have been added to actions where user variables are assigned values.
* Many other small improvements and fixes
RoboTask 11.1 has been released
