Starting and stopping a task
Aurora
Post by Aurora »
Hi,I am trying to schedule my ftp server to run from 8:00 - 5:00pm. I can see that I can schedule the server to run at 8am but there is no option to choose until when. Am I missing something here?Thanks in advance!!
lonnie16
Post by lonnie16 »
Just a thought.  If you do not want to use the "new" RoboTask function of "terminate process", then re-boot the box at 5pm.
I guess you may then have to have a conditional on the start of the ftp application/service that would test and "only" start at 8am.
What FTP server do you use? If IIS the you may start and stop MSFtpsvc service only.
Also the most another servers can work in service mode. Thus, you can start and stop the corresponding NT service.
Aurora
Post by Aurora »
Can't we start and stop a task just like a service?
The task is not similar to some application (or service) that stays in memory and executes some actions. This is only the script which contains some steps. Each task stops automatically when all steps are done. Therefore you must only start the task and do not need to stop one.
Each task may be launched automatically by some triggering event. If you configure your tasks correctly, you do not need to control RoboTask. All work will be done automatically.
